Free: 1994 TW Steering Pump
turbodrabbit'
Post by turbodrabbit' »
I have a power steering pump and bracket that is in need of rebuild. This one is leaking, so I replaced it with another one. I thought someone on this board has been thinking of rebuilding their leaking pump, you could rebuild this one and not have your vehicle in-op.
Pickup or I will ship on your dime.
1994 Turbo Wagon
1999 Subaru Forester
cartwheels
Steering pump
Post by cartwheels »
Where are you located? I'm in Southern California.
1994 Legacy TW
1991 Legacy SS
1990 VW Vanagon Westfalia
turbodrabbit'
I am in maryland, but it will fit nicely in a flat rate box for $10 and change.
1994 Turbo Wagon
chochocho
Post by chochocho »
is there a rebuilt kit for the steering pump? i hear these are super expensive new.
turbodrabbit'
I am not sure what they cost, I searched some old threads and rebuild kits were available, but they never mentioned a cost. It took me a while to find a good used unit that didn't leak, 11 out of the 12 were leaking at the junkyard.
1994 Turbo Wagon
Looks like the main seal that leaks is the one between the resovoir and the pump. It is just a o-ring. I paid $30 CDN for the rebuild kit. Has ALL the gaskets, except that one gasket for between the resovoir.
That one seal that it doesn't include is supposedly different between model years. Look through the parts catalog (or make your local parts guys do it) before you buy it. Don't forget to replace the bearing while you have it apart.
I wouldn't trust those guys. Download the parts manual and find out for yourself.
