woops, not tranny fluid
heathcom
Post by heathcom »
I thought it was tranny fluid leaking but I was checking the diff fluid, doh! Which is just clean oil looking almost yellow. Anyways, upon further inspection, the leak is coming from the valve covers dripping right on the exhaust pipe coming down. This looks like a fairly easy job, is there anything I should be concerned with before I tackle that?
Skruyd
Post by Skruyd »
If this is the first time that the valve covers are being replaced. You might run into a problem with the PCV hose on them. They get hard over time and some times just easier to cut them off and replace. Also be careful, One of the hoses on each cover is connected to a plastic pipe that runs under the intake and can break too. Other than that, it's pretty easy to do the gaskets. Have fun :-D
91 Subaru Legacy SS (Driving) 3"TBE, Vrg FCD, 440cc, HKS Safc, Vf10, ebay FMIC, Jecs
92 Toyota Corolla (fixing then selling)
06 ZZR600
Make sure you replace the spark plug o ring seals too. Wait, the might only be for the DOHC motors. I can't remember.
Skruyd
Post by Skruyd »
kimokalihi wrote:Make sure you replace the spark plug o ring seals too. Wait, the might only be for the DOHC motors. I can't remember.
SOHC---> no spark plug o-rings
DOHC---> has spark plug o-rings
06 ZZR600
kleinkid
bolt washers
Post by kleinkid »
Get new washers for the bolts, also. Part number 13271AA051
heathcom
Post by heathcom »
Got it all done, thanks for the tips. No more smokin... :)
Post by SILINC3R »
good deal i just did this a while ago and put pics up of it. i got Felpro gaskets what did yuo use
