hooking up boost gauge
reddragons
so i'm pretty good at the electrical for the backlight, but what do i need to hook up? line for the vacuum hose, and where would i hook that up?
hmmmmm........ 94 turbo legacy maroon.
1995 impreza L sedan-r.i.p.
1997 cav z24 (seized the motor)
vroom vroom party starter!
For the vacuum line, you will most likely need some 1/8" tubing that will connect to the back of the gauge with a nut and furrel. The other end, in the engine bay, can hook up to any vacuum port/line after the throttle body. I hooked mine up right at the map sensor connection.
Hope that helps.
Hope that helps.
reddragons
trying not to sound lke an engine noob too much, but anywhere after the throttle body? is that any line connected to the intake, etc?? which one's the map again? i'm still learning all the parts of this damned carstipro wrote:For the vacuum line, you will most likely need some 1/8" tubing that will connect to the back of the gauge with a nut and furrel. The other end, in the engine bay, can hook up to any vacuum port/line after the throttle body. I hooked mine up right at the map sensor connection.
Hope that helps.
Searched and found this:
http://legacycentral.org/library/literature/hbc.htm
Look @ the pic under #6.
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
reddragons
