hooking up boost gauge
Posted: Sun Mar 22, 2009 4:14 am
so i'm pretty good at the electrical for the backlight, but what do i need to hook up? line for the vacuum hose, and where would i hook that up?
A forum for 89-94 BC-BF(BJ) Legacy Owners and Fans
https://bbs.legacycentral.org/
trying not to sound lke an engine noob too much, but anywhere after the throttle body? is that any line connected to the intake, etc?? which one's the map again? i'm still learning all the parts of this damned carstipro wrote:For the vacuum line, you will most likely need some 1/8" tubing that will connect to the back of the gauge with a nut and furrel. The other end, in the engine bay, can hook up to any vacuum port/line after the throttle body. I hooked mine up right at the map sensor connection.
Hope that helps.
