1 A good cheap alternative to a bleed valve is simply to Tee off to a 4 foot length of vacuum hose that is open to the atmosphere. A long length will have so much restriction to flow that it will barely bleed off boost at all. Just keep snipping it shorter to decrease resistance and increase boost. If you want to be a purist, put a little check valve in the end so that it will not be a vacuum leak and dirt entry source when not under boost. You can also put a blob of oiled foam rubber on the end to serve as an air filter. This technique is very cheap and I have found it to be more dependable than any of the many bleed valves that I have used.
2. I was told that my Cylinder #2 had low compression as well. Since my car used no oil and ran well, I took it to another mechanic for a $50 bleed-down test. My engine was fine. The cylinder adjacent to the windshield washer fluid reservour is nearly impossible to compression test unless the fluid reservour is removed first. Another point to ponder is te fact that genuine turbo (closed-deck) engines have an oil spray system that cools the undersides of the pistons. An untrained mechanic will see or feel the oil splashing when the oil fill cap is off and misdiagnose it as blow-by. It happened to me.
eGroups Sponsor
<http://rd.yahoo.com/M=169066.1281467.28 ... EY=ECAALR4> Click Here!
Poor Man's Boost Control and Dead Cylinder
JohnnyG
I assume your bleed valve / hose is in the wastgate actuator (anywhere else
doesn't make sense0... and Yes, the open hose trick does work.... and Yes,
there are many brands of bleed valves that are difficult to control.
I will shortly post a more elaborate pneumatic circuit modification in the
File section, that provides very precise control.
John Gillon
www.clubsub.org.nz
----- Original Message -----
From: William D. Robinson <vultureboy@mindspring.com>
To: <BC-BFLegacyWorks@egroups.com>
Sent: Monday, January 15, 2001 2:38 PM
Subject: [BC-BFLegacyWorks] Poor Man's Boost Control and Dead Cylinder
John Gillon
www.clubsub.org.nz
Rod
i have an 'dual boost' pnuematic bleed valve made by Festo and it works
perfectly every time. the dual boost is switched via a electronic solanoid
which is fixed to the bleed valve.
can switch between 6psi and whatever you like on the high boost setting. it
is adjustable. i run it at 16psi.
rod.
ps. can supply part no if needed.
Sent: Tuesday, January 16, 2001 8:40 PM
Subject: Re: [BC-BFLegacyWorks] Poor Man's Boost Control and Dead Cylinder
else
> John Gillon
> www.clubsub.org.nz
at
as
more
te
that
feel
rod.
else
> John Gillon
> www.clubsub.org.nz
at
as
more
te
that
feel
