95 trans in 91
DMertine
95 trans in 91
Post by DMertine »
i have a 95 legacy L wagon with a good trans and ive been searching on this site and couldnt figure out a definitive answer if i can swap it into my 91 legacy L wagon. also would there be anything id have to pull from one car to the other to make it work? thanks for any input on this.
If they're both n/a and have cable-operated clutch throwouts, then the only other compatability issue would be the final drive ratios. If those are the same, then yes, it should swap right in.
DMertine
Post by DMertine »
ok thanks for the help
