95 trans in 91
Posted: Mon Mar 23, 2009 2:01 am
by DMertine
i have a 95 legacy L wagon with a good trans and ive been searching on this site and couldnt figure out a definitive answer if i can swap it into my 91 legacy L wagon. also would there be anything id have to pull from one car to the other to make it work? thanks for any input on this.
Posted: Mon Mar 23, 2009 4:31 am
by beatersubi
If they're both n/a and have cable-operated clutch throwouts, then the only other compatability issue would be the final drive ratios. If those are the same, then yes, it should swap right in.
Posted: Mon Mar 23, 2009 7:27 pm
by DMertine
ok thanks for the help
