restrictive DP... need opinions
Mattheww044
Post by Mattheww044 »
hey guys i just recently bought Kelly's old legacy radioflyer (can be seen in build journals)... i just noticed that someone hammered in the smaller pipe on the divorced DP so it could clear the firewall... i was told thats definately the reason for my turbo lag which is definately understandable. Now should i just take it to an exhaust shop and have them cut it and make a custom pipe to make it fit.. or just get a new DP and hammer in the firewall itself?
I'm assuming this is a divorced DP with separate pipe for wastegate gasses?
How much hammering in of the piping is done? Can you get a picture?
legacy92ej22t
Post by legacy92ej22t »
If you have to, just throw a cheap bellmouth on there.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Mattheww044
sorry, yes it is a divorce DP. I will take a pic tomorrow. Its hammered in pretty badly tho.. i would say its only getting about half the flow it would if it werent hammered in.
Mattheww044
sorry, been a little busy to get the picture... but as i said its only getting about half the flow it should... i think my step dad and i are going to take it off and cut that part out and weld in a piece that will work... does that sound safe/reasonable?
subaru_styles
Post by subaru_styles »
if i'm reading your post correctly slight restriction on a seperate wasgate dump tube will not cause turbo lag. nothings flowing in that tube till your wastegate opens, which is when your boosting at your set level
1994 SS "JDM-OEM"
1994 gt wagon, next build
1994 turbo wagon
RJ93SS
Post by RJ93SS »
weld it properly or it will crack.
let's see a pic.
i'm curious to see whu it would even come close to the firewall?
asc_up
Post by asc_up »
Yeah, I agree with subaru_styles on this. The wastegate dump tube being hammered in isn't going to cause turbo lag at all.
gijonas
Post by gijonas »
X3...this is an anti lag situation not lag causing.
asc_up
Post by asc_up »
In fact, it might even cause boost creep.
Mattheww044
hmmm... well i think i stil wanna take it off and open it up so its not so restrictive.. im sure it wouldnt hurt..... right? lol
asc_up
Post by asc_up »
Right.
gijonas
Post by gijonas »
What were saying is that it may cause overboosting if anything which - yes is bad.The problem with lag that you are experiencing is being caused by something else I.E. you have at least 2 problems at this point.
And who was this?
asc_up
Post by asc_up »
What turbo are you running? If its Kelly's old car, it might just have a decently sized turbo on there that has a little more lag than most turbos.
