broken jecs maf- you guys think it's fixable?
reddragons
when i crashed my old car it just sat. i realized that i might want to keep the jecs maf for my new car if i do enough upgrades. it basically broke where it attaches to the flange to attach to the airbox. do you think a good plastic epoxy should do the trick? i figure i could try and if i ever want too use it i'll just see what happens.
hmmmmm........ 94 turbo legacy maroon.
1995 impreza L sedan-r.i.p.
1997 cav z24 (seized the motor)
vroom vroom party starter!
thehookeup
id say as long as your not using it as a blow through MAF, youll be just fine
-93 2.2T (RIP), 93 N/A best car on earth.
-00 legGT, 18" PIAA sport mesh wheels, front/rear Rallitek sways, lowered whitelines, coming soon: 2.5L sti internals, 20g heads P&P, twin charged. motor is almost ready to go in.
Andrew
Andrew
It should work fine. It's might not "flow" to it's max efficiency lol but big whoop. But as the other Aaron said as long as the internals are fine your good to go.
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
