Hi guys and girls! A friend and I are going to be picking up a 91' Legacy Turbo Sedan tonight or tomorrow for a "project" car. The plan is to basicly turn it into a rallyX warrior. Just wanted to introduce myself to the forums because I know I will be on here a lot after we get this car. I am not new to the Subaru sceen, I have a 05' WRX wagon that I built a hybrid motor for. EJ20 heads that had some work done to them, v7 STi cams, EJ257 block/crank/rods with JE pistons Cosworth Main bearings, and ACL Rod bearings. Put a vf34 on it for the street and called it a day! I am a newbie to the Legacy's though so this should be a interesting build.
-Ryan
New to the forums!
- quasi-mod-o
92 Rally
Problem is, is that the the vf11 is shot on this thing. We have a td04 laying around thats practically new that we are going to slap on along with a tmic. Spool on the tdo4 should be to bad on the 2.2l.DerFahrer wrote:Welcome to both of you.
I'd say leave the Legacy stock if you're going to rallyX it, just fix it up and get it running good.
Since it has a small turbo, low boost, and no IC, it boost quickly and down low in the rev range. Perfect for tight rallyX courses.
You wouldn't have noticed a difference in spool from the vf11 had it been working. You may get a couple more hp out of the td04.
GodSquadMandrake
92 Rally
Yeah stuff is pretty similar to the newer cars. I like how Subarus are like lego blocks! A lot of the parts we have laying around will swap right into this thing. Free upgrades are uber sweet! The only thing that makes my head spin on these things is engine management. I understand the newer cars, but not these things! Well, I take that back. I know what it takes to make changes on OBD1 cars, but I just do not have the knowledge or will power to do so.GodSquadMandrake wrote:Well if you did all that the legacy engine should be a breeze. It's pretty much the same thing. Welcome and good luck!
