Hey guys I'm a new member with a question. I used the search but, couldn't find what I am looking for. All the information I found seemed to be geared toward older leggies (90-94) and I have a 1997 Legacy GT. I am wondering what options I have for a rear sway bar. So far it looks like whiteline is the only thing. Maybe an Outback rsb from the same generation? Will I notice a difference with an 18mm bar compared to my stock 16mm bar? Are there any that I'm missing? Thanks guys!
Corey
Rear Sway Bar for a 97 LGT
"He who begins has the work half done."
1997 Legacy 2.5GT 5sp. Dark Green
welcome aboard. Whiteline is what i use. have you checked with Cobb and Perin. i know they make them. you will see a tiny difference with only going that much. i went to 22 in the front and 20-24 adjustable in the rear set at 22. feels amazing
forgot about Cusco. did a quick search and couldnt find any. whiteline has them though. it depends if your really buy for color or name. they are all the about the same as quality. like i said i have whitelines and am very happy with them. having and blue or red sway bar would be cool but that is just it...cool. i got mine from my Subaru dealership, you should check out yours, you might get some luck if you dont from here
