ej22 piston rings
ej22 piston rings
I bought a brand new set of standard ej22 piston rings in error off of ebay. The package has been opened, but the rings are unused. These are the NPR rings you usually see. They were 50 shipped, will send them out $40 shipped.
02 WRX (The problem child)sold
93 Legacy Wagon (The dependable go getter)
05 STi
05 STi
I'll add to that
Well then I got the rest -the block
crank,rod's pistons & pins
-Jay
-Jay
Sold! Thanks.
I also have a set for ej25, minus one compression and scraper ring (ie set of three). If someone is hard up. $20 shipped. Top ring and second ring are same thickness as the EJ22s, but the oil ring is a bit smaller. These are NPR as well.
05 STi
05 STi
