ej22 piston rings
Posted: Tue Mar 31, 2009 11:47 pm
by matt72
I bought a brand new set of standard ej22 piston rings in error off of ebay. The package has been opened, but the rings are unused. These are the NPR rings you usually see. They were 50 shipped, will send them out $40 shipped.
Posted: Wed Apr 01, 2009 1:01 am
by PhyrraM
Stock bore? +.25mm?
Posted: Wed Apr 01, 2009 3:01 am
by matt72
standard/stock bore 96.9mm
Posted: Wed Apr 01, 2009 4:25 am
by douglas vincent
These are totally usable in ej22t pistons!
Posted: Wed Apr 01, 2009 5:08 am
by matt72
Yes, anything 2.2 ltr it appears.
I'll add to that
Posted: Tue Apr 07, 2009 8:17 pm
by jaybirde508
Well then I got the rest -the block
crank,rod's pistons & pins
-Jay
Posted: Fri Apr 10, 2009 10:02 pm
by matt72
Sold! Thanks.
I also have a set for ej25, minus one compression and scraper ring (ie set of three). If someone is hard up. $20 shipped. Top ring and second ring are same thickness as the EJ22s, but the oil ring is a bit smaller. These are NPR as well.
