Dash Lights HELP!!!!
92ss. ok so when its raining i get a abs, battery, and brake light. also the dash light brightness is at max. the car runs fine when this happens, and it goes away and comes back on when it wants. havent figured out if there is a pattern yet. im wondering if anyone has had this problem, also what could it be?
1997 Nissan Laurel ClubS25t
1992 Legacy SS(Sold)
nope. it only really happens when it rains.ericem wrote:Probably just the sockets on the bulbs. When you hit the dash do they come on?
Does it only happen when you have the headlights on?
It kind of sounds like an illumination control or dash lighting ground control is shorting to ground.
it does it more when the lights are on. only 2 or 3 times during the day. were woul this said ground be?
Anywhere in the harness between the illumination control and any of the dash bulbs or on the back of the gauge cluster.
I'd pull the cluster first and look for anything irregular.
might want to doubble check the charging system
when my alternator went on me those 3 lights lit up instead of just the battery light. they all went away once i changed it
LIVE LOUD, ROCK HARD!!@
1992 Subaru Legacy SS 06 WRX TMIC TD-04 MSD coil 3" turboback H&R coils GR2 shocks fsb 20mm rsb 22mm stage 2 chip
2003 silver wrx wagon 5 spd just bought!! stock for now...
just check the voltage at your battery with the car running
it should be around 14.5 volts at 2000 rpm
and not too much lower than 14 at idle with accessories on.
usually the light gets set off if its at around 12 i think so just carry a simple multimetre with you and check it when the lights come on.
-Alex
-Alex
