Dash Lights HELP!!!!
Posted: Thu Apr 02, 2009 5:48 am
by Airgne
92ss. ok so when its raining i get a abs, battery, and brake light. also the dash light brightness is at max. the car runs fine when this happens, and it goes away and comes back on when it wants. havent figured out if there is a pattern yet. im wondering if anyone has had this problem, also what could it be?
Posted: Thu Apr 02, 2009 5:20 pm
by ericem
Probably just the sockets on the bulbs. When you hit the dash do they come on?
Posted: Thu Apr 02, 2009 6:28 pm
by Airgne
ericem wrote:Probably just the sockets on the bulbs. When you hit the dash do they come on?
nope. it only really happens when it rains.
Posted: Fri Apr 03, 2009 7:17 am
by beatersubi
Does it only happen when you have the headlights on?
It kind of sounds like an illumination control or dash lighting ground control is shorting to ground.
Posted: Sat Apr 04, 2009 7:05 am
by Airgne
it does it more when the lights are on. only 2 or 3 times during the day. were woul this said ground be?
Posted: Sat Apr 04, 2009 8:07 am
by beatersubi
Anywhere in the harness between the illumination control and any of the dash bulbs or on the back of the gauge cluster.
I'd pull the cluster first and look for anything irregular.
Posted: Sat Apr 04, 2009 6:32 pm
by Airgne
thanks i will do that since the car isnt goin anywere right now.
Posted: Sat Apr 04, 2009 10:48 pm
by mexicanzero
might want to doubble check the charging system
when my alternator went on me those 3 lights lit up instead of just the battery light. they all went away once i changed it
Posted: Sun Apr 05, 2009 5:00 am
by Airgne
hmm might have to check that. i have a known good one in my other car so i might swap it.
Posted: Sun Apr 05, 2009 3:15 pm
by mexicanzero
just check the voltage at your battery with the car running
it should be around 14.5 volts at 2000 rpm
and not too much lower than 14 at idle with accessories on.
usually the light gets set off if its at around 12 i think so just carry a simple multimetre with you and check it when the lights come on.
-Alex
