rear dif bushing question!
Posted: Sun Apr 05, 2009 7:32 am
by 253.Asmo
placing whiteline rear dif bushings in place of stock, ksb1751. do I need to retain the stick mounting plate or what?, why do I still have play once they're tightened down? dumb basic question, help please
Posted: Sun Apr 05, 2009 5:22 pm
Are these the ones that go in the plate that bolts the rear diff to the crossmember?
I'm not sure whiteline makes a set for our specific application.
Posted: Sun Apr 05, 2009 7:55 pm
by 253.Asmo
They are the bushings for the front outriggers of the dif carrier where it meets the body .
I know many people have done this
Posted: Mon Apr 06, 2009 2:22 am
Yes you keep the stock plate. Basically you're putting one bushing between the body and outrigger and the other bushing between the plate and outrigger.
It should limit the up & down movement of the outrigger. Are you still seeing a substantial movement? There will probably still be a little movement, but it shouldn't be too bad.
Posted: Mon Apr 06, 2009 3:25 am
by 93forestpearl
I need to get around to doing that. The clunk gets annoying.
Posted: Mon Apr 06, 2009 4:31 am
by 253.Asmo
Yes, I still see a substantial amount of movement. It makes me think I should be retaining the stock bushing above the upper poly bushing I'm putting in, although I thought that this would be a total replacement for that bushing.
I'll put a picture up of what it looks like tightened up, have to pull the pictures off my phone a bit later.
Posted: Mon Apr 06, 2009 11:41 pm
Ok, maybe I misunderstood you initially.
You retain all the stock bushings and just add the whiteline bushings to fill in the gap.
Posted: Sun Apr 12, 2009 5:45 am
by 253.Asmo
Thanks, this is pretty much what I figured after taking another loon at the bushings. Want a picture put up for the sake of board posterity and/or quality?
Matt
Posted: Sun Apr 12, 2009 5:48 am
by beatersubi
Yes.
Posted: Sun Apr 12, 2009 6:23 am
by 253.Asmo
Cool. I'll take one tomorrow and edit this post with it.
Try to do some small part to repay the wealth of knowledge this board provides me.
Once I'm done with my 91SS into 90L sedan swap (teaser, fully rebuilt ej22t w/tdo4,tmic, lot of mount, bushing, brake and other little goodies. not crazy, just clean. I'm obviously quite excited!) I'll put a full write-up to add to the collection.
Thanks!
Matt
