rear dif bushing question!
253.Asmo
Post by 253.Asmo »
placing whiteline rear dif bushings in place of stock, ksb1751. do I need to retain the stick mounting plate or what?, why do I still have play once they're tightened down? dumb basic question, help please :)
Are these the ones that go in the plate that bolts the rear diff to the crossmember?
I'm not sure whiteline makes a set for our specific application.
253.Asmo
Post by 253.Asmo »
They are the bushings for the front outriggers of the dif carrier where it meets the body .
I know many people have done this :?
Yes you keep the stock plate. Basically you're putting one bushing between the body and outrigger and the other bushing between the plate and outrigger.
It should limit the up & down movement of the outrigger. Are you still seeing a substantial movement? There will probably still be a little movement, but it shouldn't be too bad.
I need to get around to doing that. The clunk gets annoying.
253.Asmo
Post by 253.Asmo »
Yes, I still see a substantial amount of movement. It makes me think I should be retaining the stock bushing above the upper poly bushing I'm putting in, although I thought that this would be a total replacement for that bushing.
I'll put a picture up of what it looks like tightened up, have to pull the pictures off my phone a bit later.
Ok, maybe I misunderstood you initially.
You retain all the stock bushings and just add the whiteline bushings to fill in the gap.
253.Asmo
Post by 253.Asmo »
Thanks, this is pretty much what I figured after taking another loon at the bushings. Want a picture put up for the sake of board posterity and/or quality? :)
Matt
Yes.
253.Asmo
Post by 253.Asmo »
Cool. I'll take one tomorrow and edit this post with it.
Try to do some small part to repay the wealth of knowledge this board provides me. :D
Once I'm done with my 91SS into 90L sedan swap (teaser, fully rebuilt ej22t w/tdo4,tmic, lot of mount, bushing, brake and other little goodies. not crazy, just clean. I'm obviously quite excited!) I'll put a full write-up to add to the collection.
Thanks!
Matt
