wrong whiteline swaybar
Well, I got this swaybar and guess I misinterpreted the application. I'm pretty sure whatever I looked it up on said '90-91 and '92-94 takes two different swaybars, my car is a '92 so I ordered a BSR19ZX. I now see theres a mid-year change in '92, and judging from my end-link style I have an early car because mine are the 'bayonet' style @ the lower control arm instead of a 'C'. I didn't realize this until I had bolted the swaybar into the car though, and it seems to fit fine (aside from attaching to the end-links, which I'll figure out in the near future).
Are there any other issues with running this bar on a early '92 car?
Nope....that bar from WL comes with adapters to be able to be used on the pre & post rear end link design.
You could make something to work w/ a couple lengths of all-thread, a couple clevises, and a few nuts and washers.
Just be careful with the grade of all-thread and nuts you use. All-thread from the local hardware around here tend to be either non-rated or grade 2. I wouldn't trust my car with it. Certified grade 8 can be had from online sources such as McMaster-Carr.
Alternatively you could just upgrade to the C-style mounts as I and Josh have done. Thanks to Joshs' write up it makes it easy.
- Findlay
http://www.toolsource.com
No extra parts in the shed. I'll be fabing something up.
Is the write-up your refering to the one involving swaping the rear arms? Or can I attach the 'C' style to my arms?
'92 Legacy SS, AGX, GC coilover, ALK, 20mm ARSB, FCD, MBC, iceracer, rallyx and DD
'87 Mustang GT roadracer, to many mods to list
You'd need the other style of lateral links. The ones w/ the bracket on the bottom.
Correct. You would need new laterals for the C-shape links. If you're considering continuous mods to your car (i.e. making it a project car) I highly recommend the whiteline laterals, c-links, and low conformance poly bushings. Again, simalar to what Josh has done. If you have the extra cash its worth it. I ended going this route because of a bent lateral on my swap car...the whiteline parts were comperable in cost to dealer OEM parts and of course offer better performance. Not to mention, the whitelines are adjustable.
- Findlay
