TD05-16 on Nabisco F/S
Adam West
Post by Adam West »
Not mine - try to get the oil lines with it if you can...
http://forums.nasioc.com/forums/showthr ... ?t=1744496
4.23 edit - another one, same one?
http://www.rs25.com/forums/vbclassified ... ad&id=6129
Good hunting!
stef1825
Post by stef1825 »
hummm what the h*ll
1992 Legacy Turbo AT
1994 Legacy turbo mt, 16G, TMIC, 10psi, TBE, BOV, 4.11 rear LSD .... and more :P
wtdash
Post by wtdash »
Here's the correct LINK.
Adam, You're a bad influence. :-)
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Adam West
Post by Adam West »
Sorry about the wrong link B4. I may be wrong about the oil lines too but Jake15's brother bought one of these without and never could find any to get it to work and they are at the freaking capitol of Subaru in WA state...but if seller has them then this is a semi good deal. You may want to ship it to deadbolt for a refurb on the way to you...Good luck!
BSOD2600
Post by BSOD2600 »
Oil lines? From my td05 install, I just used the stock oil lines from the VF11 and bolted them up. Do you mean the coolant lines on from the nasioc post are missing?
'11 WRX Limited
'94 TW | R.I.P.
Adam West
Post by Adam West »
Yes, coolant lines...my bad. Buyer beware.
Aerotech
Post by Aerotech »
You can re-use your original coolant lines, but you'll need to
1. separate them, and
2. ream out the openings w/ a step drill bit, and buy the larger banjo bolts that the -16G uses. BTDT. Work fine, last long time.
Jerry
Adam West
Post by Adam West »
Added one from another forum...Cheers,
