TD05-16 on Nabisco F/S
Posted: Thu Apr 16, 2009 10:59 pm
by Adam West
Not mine - try to get the oil lines with it if you can...
http://forums.nasioc.com/forums/showthr ... ?t=1744496
4.23 edit - another one, same one?
http://www.rs25.com/forums/vbclassified ... ad&id=6129
Good hunting!
Posted: Thu Apr 16, 2009 11:00 pm
by stef1825
hummm what the h*ll
Posted: Thu Apr 16, 2009 11:45 pm
by wtdash
Here's the correct
LINK.
Adam, You're a bad influence.
Posted: Fri Apr 17, 2009 12:20 am
by Adam West
Sorry about the wrong link B4. I may be wrong about the oil lines too but Jake15's brother bought one of these without and never could find any to get it to work and they are at the freaking capitol of Subaru in WA state...but if seller has them then this is a semi good deal. You may want to ship it to deadbolt for a refurb on the way to you...Good luck!
Posted: Fri Apr 17, 2009 1:42 am
by BSOD2600
Oil lines? From my
td05 install, I just used the stock oil lines from the VF11 and bolted them up. Do you mean the coolant lines on from the nasioc post are missing?
Posted: Fri Apr 17, 2009 1:47 am
by Adam West
Yes, coolant lines...my bad. Buyer beware.
Posted: Fri Apr 17, 2009 3:18 am
by Aerotech
You can re-use your original coolant lines, but you'll need to
1. separate them, and
2. ream out the openings w/ a step drill bit, and buy the larger banjo bolts that the -16G uses. BTDT. Work fine, last long time.
Posted: Thu Apr 23, 2009 7:19 pm
by Adam West
Added one from another forum...Cheers,
