Volvo intake tube identified.
jefferson
Post by jefferson »
I went to the pick and pull today to get some of the 92 up rear lateral links so I could update my car. 2 different yards and I came out empty handed on those.
I did score one of the intake tubes that fits our airbox hole snuggly. I can't say 100% that this is it because I can't find my old airbox lid to try it on. Everything checks out as far as I can remember. It came out of a 91 Volvo 960 turbo. It is the tube between the maf and the airbox and the maf bolts to the airbox lid, so you have to unbolt the maf to get the tube out. Cut the straight section off and flair one end. I used a metal funnel and a heat gun to make the flair. Remove the rivets from the bracket holding the rubber seal and insert the tube. You may have to sand the edges of the hole in order to get the tube to go in and it will need to be inserted from the inner fender side. I then used some general purpose low density foam tape weatherstrip that was 1/2" thick and 3/4" wide to seal the hole in the metal behind the airbox so no engine compartment heat got to the intake . Ran a strip of it around the tube and inserted the tube until the foam sealed the hole. Aluminum taped everything up to hold things in place. Sorry there are no pictures. I hope my description helps with your understanding.
Also remember that the shorter the tube the more air it will flow.
Jeff
Pics would help, but it sounds cool.
Any Legacy or Impreza lateral links will work up to at least '99.
yes....need pictures :)
n2x4
Post by n2x4 »
Bump for pictures!
SUBARUEHS Racing
253.Asmo
Post by 253.Asmo »
this thread is worthless without pictures.
'94 White SS / 5MT - daily, absolute piece of a beater
'90 Red Sedan - EJ22T / 5mt Swap - drove it, SOLD it
'91 black SS / 5MT - (215/230k miles. eng/body)
[RIP - drove, hit, cracked a piston, swapped and stripped for swap again]
jefferson
Post by jefferson »
Pictures should be up sometime soon for all to see.
jefferson
Post by jefferson »
To see pictures and info please go to the new thread about Volvo intake pics for jefferson.
