i have a crazy front control arm idea
jeffast
Post by jeffast »
has any one tried putting impreza control arms on a legacy?
92 SVX LSL tour- 5spd swap baby
92 turbo touring wagon now also 5-speed swapped
89 xt6 stock
[quote="danetrain"]Fuck wyoming[/quote]
They're essentually the same, at least up to the 2001 MY.
Aren't the front pivot bushings different in size, or something like that?
jamal
Vendor
Vendor
Post by jamal »
2nd gen imprezas have a thicker front bushing. You can swap the bushings out or shave them down.
WRX sedan control arms are wider, so to use them you would need wrx axles, among other things. Some are aluminum, and some add more caster than others.
GodSquadMandrake
Post by GodSquadMandrake »
Jamal, I assume that STI control arms would be the same fitment as the WRX control arms. Would it be just as easy as axles, swaybar endlinks, and tie-rod ends? Or would you need to sway like the whole steering rack? Would the ball joints work or would you have to switch hubs too?
-Doug Wilson
