Need your help guys on vacuum hoses
The outsider
Post by The outsider »
Hi, this is my first post ( HI :-D ) and i need your help guys...
this may shock/upset the purist but this is my mode of transport
but as you can see it was less than reliable so drastic action was taken
1992 uk Legacy EJ20T......
..but now im stuck.... when i got the engine all the vacuum hoses were off and i dont know what goes where
can someone please help me out with these as the haynes maunual and even the workshop cd doesnt shed enough light on these... ( i've tried flaging over legacy owners to have a look under the bonet, but they think im mad and speed off :( )
oh for those interested i'll post a full (ish) project report once im allowed in.....
cheers ...........The outsider
vw baywindow EJ20T
n2x4
Post by n2x4 »
Try this one out:
SUBARUEHS Racing
PhyrraM
Post by PhyrraM »
The large hose straight out the bottom of the bigger goldish soleniod goes to the intake track after the AFM, but before the turbo.
The other large hose coming out 90 degrees from the bottom goes to the wastegate actuator.
The smaller one coming out 90 degrees from the top of the goldish soliniod goes to the nipple on the turbo outlet.
The very small one coming from the other soliniod near the reddish-brown connector goes to manifold vaccuum. One of the three nipples near the throttlebody.
The open nipple on the soliniod with the reddish brown connector gets looped around and connected to the open nipple on the last sensor in the picture. That's the MAP sensor, the one with the open nipple pointed down sort-of hidden by the wires.
The outsider
Gentlemen, you've made me one very happy camper!!
it's taken me weeks and several different forums, from all across the globe to finally get an answer.....
....man love and beers* goes out to you.!!!!!!!!!
* if im ever in your neck of the woods , the beers are on me!!
vw baywindow EJ20T
Dynamic Entry
Post by Dynamic Entry »
deal.
not that I am taking credit for the diagram, but just deal on beers anyhow.
btw, is your name a Camus reference?....
also, welcome aboard and all. And why are you ashamed that your mode of transport is a flat-bed?
Andrew
16 Outback - wife's daily
95 Gravel Express - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
$135 before shipping from 1stsubaruparts.com for all those hoses. Is it a good idea to do this or just buy some silicone hose in those diameters and cut it yourself?
Bdub
Post by Bdub »
The generic stuff does not fit as well as the OEM.
You could go either way, depending on your budget, but be prepared for hoses not snugging properly if you go aftermarket.
Through The Generations...
91 SS 4eat
95 LSi 4eat- Sold
07 2.5i 5mt- For Sale
13 STI Sedan
Aerotech
Post by Aerotech »
Are you in the UK? Number plate looks like it...
Nice camper... is that one of the side-tilt pop tops? Devon, I think?... Cool flares, too.
Where are you putting the radiator?
Jerry
n2x4
Post by n2x4 »
I've never had a problem with vacuum hose from the auto parts store as replacement. I zip tie all the ends just to be safe. No problems yet...
SUBARUEHS Racing
asc_up
Post by asc_up »
n2x4 wrote:I've never had a problem with vacuum hose from the auto parts store as replacement. I zip tie all the ends just to be safe. No problems yet...
I'll second that.
The outsider
.... im going to have to go with aftermarket hosing as nothings located in the same place as the car......
I wish mine was the flat bed most of the time :lol:
yeah, im in the uk......the pop goes straight up,, which is a nighmare when you try and get it down as it always falls one end at a time and never lands where it should....
Radiator is going underneath at an angle (front end down as to scoop the air) got to try and work out a lifting mech as i'll need to raise it for speed bumps ( us brits love em :x )
came across another problem at the weekend.....
does anyone know what this is .....and does so i can work out where is wires too....
cheers guys
vw baywindow EJ20T
PhyrraM
Post by PhyrraM »
Looks like the resistor that is only used on the automatic transmissions. Was it near the pressure sensor/MAP sensor?
The outsider
That's part of the problem dude, because i got it all already striped out of the car ive got no reference point for where it should sit in the car....
vw baywindow EJ20T
That's most likely the dropping resistor for the auto transmission, or it may be the resistor for the daytime running lights. Either way, you don't need it.
Apex3
Post by Apex3 »
I replaced all the smaller hoses with universal, they all fit pretty tight, and it was something like $10. The bigger hoses you have to get elsewhere though...
