Wastegate pressure on stock vf11 seems low
jefferson
Post by jefferson »
I hooked up the stock turbo to run wastegate boost and am only showing 4.35 lbs. [had to convert mpa] and this seems low. I searched and didn't find the info I was looking for. What is the wastegate boost on the stock vf11? Thanks.
Jeff
jefferson
Post by jefferson »
Anyone?
wtdash
Post by wtdash »
5-6psi, from what I've read.
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
BXSS
Post by BXSS »
5psi.
Are you intercooled?
If so that may explain the drop in pressure.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
jefferson
Post by jefferson »
No, not intercooled. Maybe a weak spring?
BSOD2600
Post by BSOD2600 »
You could test it with a boost hand pump tool to see when the wastegate is opening.
'11 WRX Limited
'94 TW | R.I.P.
impreza_GC8
Post by impreza_GC8 »
5 psi is what I thought wastegate was.
-'97 Outback - EJ25 block/pistons/HLA heads, EJ22T crank/rods/ECU, EJ20G intake manifold/fuel rails/440cc injectors, VF8 @ 11psi. . . . Fuel cut > me
