LOTS 'O parts leftover from build LOWBALLERS WELCOME
I have a VF11, SAAB IC, Head gaskets, and alot of other gaskets and o-rings the Gasket rebuild kit from Subarugenuineparts.com was bought but i only needed one gasket from the kit PM for a specific gasket and ill see if i have it. intake mani off 2.2L, single cam heads, cams and all supporting parts for the heads, "Turbo" bumper cover black. All parts were taken off a 94' Turbo Wagon Brand new from NAPA high output water pump was installed then removed for a better one, Timing belt, STI intake box, STI cat and down pipe. Im selling this stuff CHEAP and hoping someone who was going back to stock or just needed somthing to get them by will be interested. MAKE AN OFFER ON WHAT YOU WANT LOWBALLERS WELCOME!!!!! PM FOR PICS
Do you have cam seals for the EJ22T or valve cover gaskets or could you just list the gaskets and stuff you have for the EJ22T? That would make it easier.
I just picked up a motor that could use some gaskets and seals before I put it in. Also needs hoses and stuff but I doubt you have any new hoses.
