Need help seperating engine from tranny
xoomer
Post by xoomer »
Ok,
Today was an interesting day... Started the removal of the engine on my legacy.... I got it down everything separated.. the turbo from the down pipe, the bell housing all the vacuum hoses... Hook the hoist up and find out that I need two new engine mounts... (both Broken) and then we cant get the engine free... try jacking up the transmission... still nothing... any tips... tricks or ideas?
Zach
http://www.zacharymonroe.com
RSS O'Reilly Auto Parts.
My Stable,
'91 T-Leg, '83 Brat, '2x88 XT6 Auto, 87 XTT
PhyrraM
Post by PhyrraM »
Broken mounts are common.
If it's a 5-speed turbo Legacy.....did you pull the clutch release fork pin?
92ss satinsvoice
Post by 92ss satinsvoice »
PhyrraM wrote:Broken mounts are common.
yep yep
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
Matt Monson
Post by Matt Monson »
I've retitled your thread. In future please try to choose a title that let's people know what the topic is before they click on the thread.
Your problem is the guide pins at 3 and 9 o'clock. They are rusted in place. Some PB blaster soaking can help. Heat can also sometimes do the trick. On really stubborn ones, I use a paint scraper to get the two to start to seperate and then work a screwdriver in between the two bellhousings.
This isn't like the seal in the casehalves of the engine or some other sealing face. Other than cosmetics, you don't have to worry about damaging the mating faces. You can beat them up and still have everything work fine.
Sometimes when they are really super stubborn I drop the dust shield on the bottom (two 10mm) and get a prybar in there between the two of them.
Also, dropping the assembly off the cherry picker onto the crossmember a couple of times can sometimes knock them loose. Bottomline is you just have to work it for a bit and get aggressive with it.
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
xoomer
Post by xoomer »
Its separated... but will not come more than an inch or so apart.... and we were beating on it.. Which reminds me I need to put up a parts needed post.... I need a coolant reservoir for the top of the engine now. :evil:
Pull the clutch fork? is that something that it is needed to get this engine out?
My Stable,
Fkyx
Post by Fkyx »
xoomer wrote:Pull the clutch fork? is that something that it is needed to get this engine out?
You don't have to take it completely out, but you need to take it out of the ears on the throwout bearing.
This "pin" needs to come out to free the fork. It can be a real pain sometimes.
xoomer
Post by xoomer »
SOB!
My Stable,
kleinkid
Post by kleinkid »
This thread is another example of how great a forum legacycentral is. Honest people who are sincere and just want to help.
FKYX-- that picture is an excellent illustration.
I will be doing an engine pull soon and will be at the same place xoomer is. Thanks.
xoomer
Post by xoomer »
Absolutly I wish I had known this when I started that engine would be out.. instead of sitting half in
My Stable,
asc_up
Post by asc_up »
Hahaha I ran into this same problem about a year ago, posted the same question and got the same answer. The engine will come apart extremely easily once you pull that out ;)
xoomer
Post by xoomer »
This is what I have for a pin so Apparently sticking a bolt in there is not an option :evil: what do I do?? I got the engine out... when I took the starter out I just unbolted the pressure plate from the flywheel and was able to get it out...
My Stable,
PhyrraM
Post by PhyrraM »
Ouch. That's pretty wasted.
Take a good sharp punch and make a good sized dimple near the outer edge. Place your puch in the dimple at about a 45 degree angle and whack it counterclockwise. With a touch of luck it will break free and then you can most likely spin it out with your finger or a pair of channel locks.
Get a new one to install.
FYI, once everything is taken apart, there is a retainer on the back of the throwout bearing that needs to be slipped forward. Once that is done then the thowout bearing will slide out of the pressure plate. Reassemle the (new?) throwout bearing on the input shaft and release fork and replace the pin. The throwout bearing and pressure plate will lock together automatically when the engine is replaced.
xoomer
Post by xoomer »
Well, What size is that hex? I was gonna try that first but I will have to find the correct one first! then to the punch...
My Stable,
PhyrraM
Post by PhyrraM »
You need a 10mm allen wrench or allen socket.
There are usually VERY tight if they haven't been attended to regularly. I've broken 3/8 ratchets loosening them. Get a 1/2 drive socket if possible.
xoomer
Post by xoomer »
I work for Schucks/O'Reilly's so Hopefully its on my shelf!! I'm trying to get this thing together for Summer..
My Stable,
