Teaser Picture of my EJ20R heads from Delta Cam
douglas vincent
Post by douglas vincent »
1997 EJ20R heads from the "hot" Legacy twin turbo that I bent all the valves on.:rolleyes: I sent them up to Delta Cam and had them do 1mm oversize valves in just one side crisscross style. You know, for bling.
Actually, I guess the EVO builders have started to do this with results, so I thought I would give it a shot.
smh0101
Post by smh0101 »
Dammmnnn
Did they do some work on the combustion chamber? looks like its gonna raise the comp ratio...
I wonder if that helps promote chamber swirl? Looks like they do some good work!
Interesting. Did you get the cams altered at all?
bmxpunk
Re: Teaser Picture of my EJ20R heads from Delta Cam
Post by bmxpunk »
A big bump up on this! Looks like I need to come around here more often again!!
How did it work out Doug? and do you have any other 20r heads laying around? ;)
2011 Mini Countryman S All4
1970 Honda Ct90
Re:
beatersubi wrote:I wonder if that helps promote chamber swirl? Looks like they do some good work!
LOL
Shhh.
I, too, am interested in performance results.
