Off the car(s) right now:
'98 2.2L Automatic AWD trans. 155K. Some newer internal parts (have to read that repair bill from 2003 again). Shifted fine when lot driven (motor was bad) up to 40MPH. Some leaks but nothing fresh. Adjuster on shift cable broke when it was removed from the car. Not shipping of course. Will meet within 50 miles or so once the wagon is running. Or pick up in Greenfield WI.
$150 o.b.o.
'98 2.2L 155K. BAD VALVES. Runs, but not well. Leaking out of the right valve cover/rear cam seal. Good for rebuild only. Short block MAY be okay. Not responsible if it's junk. I bought the car after the timing belt came off/tensioner broke. Put it back together and it ran. Kinda. Drove it around the lot at work ONLY, and back and forth into the shop. Did no compression tests, but the coolant and oil were clean. A/C and Alt. bracket not included. May part out if requested. Intake manifold and attached parts also available, but I have to go through it yet. Not shipping of course. Will meet within 50 miles or so once the wagon is running. Or pick up in Greenfield WI.
$150 o.b.o.
Stock BD tails, no cracks or deep scratches
$10 each + shipping
Stock GT fogs, pitted and a little hazy, but not yellowed or cracked
$10 each + shipping LEFT SIDE SOLD
Stock left one piece headlight, yellowed but not cracked or scratched. Tabs perfect.
$10 + shipping
Stock right one piece headlight, yellowed but not cracked or scratched. One tab epoxied back on.
$10 + shipping
Sedan muffler off my GT (flange getting thin)
$20 + shipping
Wagon muffler off my L (with chrome tip)
$15 + shipping
Rear 16MM sway bar off my GT
$10 + shipping
Wagon midpipe with round resonator
$10 + shipping
Sedan midpipe with flat AND round resonators (round one has a SMALL leak, thin flanges)
$10 + shipping
Single port exhaust manifold
$10 + shipping
Not pictured:
2.2L thottle body
Intake resonator box
2.2L AT starter
Sedan power antenna SOLD
ALL $10 + shipping
PM me if interested or with any requests/questions.
Watch this space for more!!
