hey guys i started realizing awhile after i got my car that some hesitation issues started coming up. so i took it to matt at 555 motorsports to see if it was maybe tuned out of whack, he suggested putting new wires/plugs/fuel filter etc before starting the tune in case that was the problem.
so since my coil pack is relocated i had to get the7mm do it yourself kit for the wires. i ended up getting NGK-R bk7re ( i believe was the part #), which matt suggested to gap at 28/1000. so i did that, and right when i put the plugs and wires back in i took it for a spin, it ran absolutely amazing i was sooo excited. then the next day it just started running crappy again like before i changed wires/plugs.
anyways i just dont understand, now i made sure that all 4 plugs are in there tight enough, all 4 plug ends are on there as good as they are gonna get, and all of the ends in the coil pack are all in there fine. And it still runs like crap like its missing or something. im not quite sure if i should just go out and get more plugs/wires but if its going to do this again then there is no point... so im just looking for suggestions i guess
thanks guys
spark issue....
Mattheww044
Mattheww044
Have you had a look at the plugs? Since the new ones fixed it for a while and then failed it seems likely that they are fouling up with something, could be petrol, oil, sucking up brakefluid, who knows.
If plugs get fouled it can be caused by contamination, too cooler plug, to much load on the plug.
Just reread your first post, twenty-eight thou isn't enough gap for a subaru, set it to specs when you are inspecting them and see if that helps.
Mattheww044
ok, so what would you recommend for the gap then?
i got new plugs so im going to clean out my air filter, the fuel filter is brand new. also matt recommended the ngk bkr7e, i was running the 6e, so i got the 6e again just incase that had somethin to do with it.
Mattheww044
ok, well my air filter is drying now, when we pulled it off we noticed some oil (im guessing) in the MAF,so i will try to pick up another MAF when some more money comes my way. other than that i got new plugs so i will put those in in the morning and see how that works. thanks for the help
Mattheww044
