so i installed a set of kyb gr2 struts h&r springs and a whiteline rear adjustable swaybar.
car drives awesome feels like its faster and brakes better because there is less squat, much more corner turn in when on power (feels like the car wants to turn and slide the tail out rather than understeer) and in general significantly less body roll. i still want to upgrade my front swaybar and put the rear on the stiffest setting though.
as for ride height i'm very confused. i double tripple and then quadruple checked the spring numbers and the strut numbers on the board and looking through catalogues so i'm 120% sure everythings right for my model year (1992) buut. the website states the springs lower the car 1" rear, which they did, and 1.25" front which they lowered almost 2" ground clearance is still fine with about 4 or so inches at the lowest point which is in the middle of the car so not even really at the front.
the car looks cool, it has that much more aggressive front squating down look and i like it. (pictures will come i've just been too lazy to give my car a photoshoot lately.
so has anyone else had this problem?
before doing the swap the hub to fender measurement was about 15" front and 14.5" rear now its 13"front and 13.5"rear.
-Alex
did up my suspension, ride height messed up??
mexicanzero
LIVE LOUD, ROCK HARD!!@
1992 Subaru Legacy SS 06 WRX TMIC TD-04 MSD coil 3" turboback H&R coils GR2 shocks fsb 20mm rsb 22mm stage 2 chip
2003 silver wrx wagon 5 spd just bought!! stock for now...
It probably did lower the front 1.5", but came out as 2.0" because your front was 0.5" higher than the specs of the OE suspension.
Legacy Central
mexicanzero
oohh thats possible i guess, although i swear i saw a pic of someone elses car on h&r's and it didnt look so low... meh i'm happy anyways i was just curious.
