boost oscillations
BSOD2600
boost oscillations
Post by BSOD2600 »
How much oscillation while on full boost would be considered normal? Using a hallman MBC with the stiff spring on my TD05. I was doing data logging and noticed it fluctuates ~2 PSI. Can't say I really notice it on my autometer boost gauge (but possibly because I'm paying attention to the road instead). I assume this fluctuation is from the MBC spring bouncing on the wastegate?
Thoughts? Would using the stock boost solenoid help to lessen it?
'11 WRX Limited
'94 TW | R.I.P.
Skruyd
Post by Skruyd »
On a MBC will always fluctuate. The electronic ones don't do it as much because they can always adjust themselves.
91 Subaru Legacy SS (Driving) 3"TBE, Vrg FCD, 440cc, HKS Safc, Vf10, ebay FMIC, Jecs
92 Toyota Corolla (fixing then selling)
06 ZZR600
Adam West
Post by Adam West »
I have the upgraded MBC from TurboXS with the bleed valve - supposed to take care of this issue??? but haven't put it on yet...
http://www.turboxs.com/uploaded_images/522.pdf
Where are you measuring boost? Stock vacuum/boost port?
BSOD2600
Post by BSOD2600 »
Those numbers come from the MAP sensor via ECU. My boost gauge is teed off the umm front left intake line.
'11 WRX Limited
'94 TW | R.I.P.
