Injector #2.....i Think its Electrical!!!!
Posted: Mon May 25, 2009 3:56 pm
well ive done the whole tune up deal and i cant get this thing to run right....it seems like cyl 2 is not firing....or not firing well.
first i switched injectors maybe seeing if it was the injectors...not the problem as the issue was on the same cylinder.
so today i called in sick and am gunna see if i cant track down where the electrical issue is....any suggestions!!!
also when i unplugged the connector on the problematic cylinder...nothing happened except it continued to run like crap....but when i unplugged a known good running cylinder, it ran even worse! so that leaves me to believe that somewhere in the connection, there is an issue! please help! need to get back to work!!!
