WRX trany swap: do I need rear hubs or hubs and knuckles?
baddriver
Post by baddriver »
I have a 1991 turbo Legacy with a bad transmission and I'm getting parts for a WRX transmission swap.
Right now I have:
a complete 2003 WRX transmission assembly
rear diff
rear axles
wrx flywheel
wrx clutch
wrx pressure plate & tob
I want to be able to swap out full WRX rear axles if needed
in the future so to do this do I need the hubs,
will I need anything other than hubs to match the knuckles.
Would there be any issues with me n me keeping the 91 legacy parking brake assembly, knuckles,rotors,, etc and just adding the hubs to what I have for the swap?
Also is there any difference between the stock 1991 LSD unit and a 2003
LSD unit?
I am aware of ratio difference for teh whole differential , but I
am focused on the LSD or VLSD units themselves.
No, the VLSD's should be the same.
n2x4
Post by n2x4 »
You don't need to replace anything to get the WRX driveline to bolt up. WRX axles will fit in place of the Legacy axles just fine. No hub/knuckle swaps required.
You have all the parts you'd need to do the swap now. The only thing you'll need to change is the pinion flange on the rear diff if you plan to reuse the Legacy driveshaft. The bolt spacing is a bit different between new and old styles. No big deal to swap though.
SUBARUEHS Racing
nicv217
Post by nicv217 »
n2x4 wrote:You don't need to replace anything to get the WRX driveline to bolt up. WRX axles will fit in place of the Legacy axles just fine. No hub/knuckle swaps required.
this sounds stupid but how do you change the pinion flange on the diff in the future i will be doing this swap
roundeye
Post by roundeye »
with the driveshaft out, remove the nut recessed in the center of the flange, pull the flange off (tap gently w/ a hammer if necessary), put the new one on, and torque to 123-145lb-ft.
nicv217
Post by nicv217 »
thanks very much
race_to_live
Post by race_to_live »
i also have a bad trans in the 91 and would like a trans that would hold a bit more power. i have been thinking about doing some kind of wrx tranny swap but i don't know what to get. do i just need a wrx tranny, the clutch and flywheel kit, and the pinion flange off the wrx rear diff, to just bolt on?
-91ss, 250,000mi rebuilt, tmic, tdo4, agx's w/groundcontrol, f/r strut bars, rust
-83 gl wagon...350,000mi custom dents
-62 honda 55, (moped)
-74 Yamaha rd 350
race_to_live
what about all the electrical stuff? the neutral and reverse switches? do they work?
-74 Yamaha rd 350
