Fuel Controller wire ID.
Skruyd
Post by Skruyd »
Mmk, got the HKS Super AFR and just wanted to make sure the wire's I'm hooking up to are the right ones. Measure twice cut once :-D or in this case connect the right wire and don't fry the ECU :twisted:
12v ignition = c10
ground = c11
TPS signal = b2
Air flow signal = a10
RPM signal = c16
And these are the pin outs from the ecu side :-D
Thank you everyone.
91 Subaru Legacy SS (Driving) 3"TBE, Vrg FCD, 440cc, HKS Safc, Vf10, ebay FMIC, Jecs
92 Toyota Corolla (fixing then selling)
06 ZZR600
I've fixed the air flow, 12v ign. and ground pins, and just for clarification, I'm going to put the actual ECU connector instead of the abbreviation from the factory book.
12v ignition = B48 pin 2
ground = F47 pin 14
TPS signal = B58 pin 2
Air flow signal = B48 pin 9
RPM signal = B56 pin 16
Where did you get the pin information above?
Skruyd
Post by Skruyd »
Thanks for the info :-D. I got my info from 1991 Service Manual Section 6 pg. 12 Fig. 15.
06 ZZR600
section 6-3?
Skruyd
Post by Skruyd »
Nope, it 6-2. I was using the schematic and taking a stab at it. It didn't give much info on which wire did what. Just showed what connected to which part. I think I should have looked into book 2?
06 ZZR600
Yeah, should have used book 2.
n2x4
Post by n2x4 »
Legacy777 wrote:Yeah, should have used book 2.
Screw book 2, just ask Josh :-D
SUBARUEHS Racing
Skruyd
Post by Skruyd »
I kind of did that, but didn't really want to because I had the info. Just didn't want to be stupid about it. :-D
06 ZZR600
