I just upgraded to STi suspension, so my old suspension has to go. I don't know what they really go for, so $100?
Should be a decent upgrade for a non turbo, you'll need to reuse the rear top hats though, as I needed them for the STi rears. As far as I know there's 140k miles on them, not sure if they've ever been replaced but they seem to still be good.
EDIT: $70obo lowball me
Will trade or partial trade(either direction) for the following
-20mm front sway bar
-Whiteline rear sway bar
-Any other suspension upgrade
-Weighted shift knob
-Stock Front grill
-Stock hood scoop
-Whatever else you may have
Well how much for just the fronts? That's really what I'm needing anyways. Some dumbass cut the springs one rung on the front to drop it ghetto style..
Still have the rears? Mainly I just need springs (gotta check if they work on 90 N/A, and if they are a higher spring rate). I'm over in Moscow if you're still in pullman.
90 Legacy L AWD 5mt
Formerly of the USMB but moved from an RX to a Legacy
