Gauge Mounting Locations
Slow Hatch
Post by Slow Hatch »
I've moved my radio down to where the flip open tray was and am going to place the gauges where the radio was by either making a plate out of plexiglass or sheetmetal painted black. I'll get some pics once I get it done. Where do you guys have yours mounted????
I put gauges there too. I didn't even bother with proper mounting -- I just used black foam (packing material from a Dell computer, I think) and cut it into roughly the right shape, with some oversize, and wedged it in there.
It actually looked fine. Not nearly as bad as it sounds.
BSOD2600
Post by BSOD2600 »
Boost gauge is mounted on the steering wheel column, which lines up exactly in the middle of the tach. AFR gauge is currently temp mounted above the left center air vent.
'11 WRX Limited
'94 TW | R.I.P.
SLODRIVE
Post by SLODRIVE »
I threw my boost, A/F, and oil pressure gauges in an old WRX A-pillar pod and trimmed it to fit. Not exactly "concours", but really easy to see. :smt104
http://www.slodriveracing.com
-And more!
Bdub
Post by Bdub »
This was "temporary" but so far is going on over a year...I used a piece of chain link fence and bent it into place under the ashtray. This way I didn't drill or remove anything on the car, just in case I wanted to get rid or it, or move it. It's tilted up so it is pretty visible while driving. It isn't very obvious and pretty stealth looking. Which is why I chose the location. Can't open the ashtray, but I don't smoke anyways.
Through The Generations...
91 SS 4eat
95 LSi 4eat- Sold
07 2.5i 5mt- For Sale
13 STI Sedan
I have also disabled my ashtray, I cut out the front/bottom and added a plastic sheet that holds two flush-mounted gauges. So it looks like that ^, but on the ashtray and without a bracket.
ScottyS
Post by ScottyS »
I located 3 in the A-pillar, using a "one-size-fits-all" mount from GlowShift that I trimmed to fit. I found some paint at the local hardware store that was a PERFECT match to the gray dash color, so it actually looks OEM from the outside.
Now I need to mount the wideband, probably will go down where the ashtray used to be.
1991 SS build thread: http://bbs.legacycentral.org/viewtopic.php?t=40430
magicmike
Post by magicmike »
If havent seen this already 8)
Vid:
http://www.youtube.com/watch?v=tZkwx7ou49Q
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
All_talk
Post by All_talk »
I've done just about what you are planing for my wide band O2. Used a sheet metal plate painted black, then brushed it with steel wool to better match the plastic. I also flipped my 1/2 din pocket and mounted it where the ash tray was. It works fine there but I'm not sure I really like the look of it. The whole setup looks a little to aftermarket for my taste, at some point I figure I'll rework it and add a second gauge mount.
BTW, my boost gauge in built into my cluster with an oil pressure and volt gauge.
Gary
gijonas
Post by gijonas »
I have also done the heater vent delete idea,i felt they should go where you can see them.
Very nice Mike!
Slow Hatch
gijonas wrote:I have also done the heater vent delete idea,i felt they should go where you can see them.
Ehh, I am a to fond w/ having my A/C blowing out at me :-D
magicmike
Post by magicmike »
Legacy777 wrote:Very nice Mike!
Thank you!
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
magicmike
Post by magicmike »
There is plenty of air coming out of the driver's side vent and the left side passenger to be cool.
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
