Problems removing speedo cable from trans...
Posted: Tue Jun 09, 2009 1:23 am
by skatedees
So a while back I posted asking how to take off the speedo cable from the trans.
http://bbs.legacycentral.org/viewtopic. ... highlight=
I thought it came off from there at the time. Turns out it breaks part way up, so I took the clip off, breaking it in the process, `:x and it wasn't coming apart at all. So I pulled and pulled until it finally broke. Literally.
So now I'm trying to replace it ......... then this happened:
As you can see, there is no 'bolt' left. the damn thing snapped off.
So I'm wondering if anyone has any ideas of how to get it out.
Here is a pick of the new part for good measure:
Posted: Tue Jun 09, 2009 1:29 am
by gijonas
Start using a medium sized screwdriver and a hammer?.Start driving it in on the edge in a counterclockwise direction to get it to turn? Not sure if you have enough room in there or no for that.
Posted: Tue Jun 09, 2009 3:14 am
by Bdub
^^^ That would be my first attempt.
Fortunately, it's just plastic, and I can't even remember how much room is in that area, but see if you can break apart the threaded area, then it'll pull right out.
I broke a camshaft sensor to a Cummins Diesel not too long ago, which looked just about like that, and I drilled it out with a 90* drill to break it free.
Posted: Tue Jun 09, 2009 3:30 am
by fishbone79
The exact same thing happened to me... I don't know if I necessarily recommend the following, but I heated the side of the gearbox around the fitting with map gas. I only heated it just enough so that the plastic turd turned a little mushy, then I folded it in on itself with a screwdriver and pulled it out with needle-nosed pliers. All my other attempts at extraction made a mess and were getting crumbs of crap inside the gearbox...
Posted: Tue Jun 09, 2009 1:47 pm
by skatedees
fishbone79 wrote:The exact same thing happened to me... I don't know if I necessarily recommend the following, but I heated the side of the gearbox around the fitting with map gas. I only heated it just enough so that the plastic turd turned a little mushy, then I folded it in on itself with a screwdriver and pulled it out with needle-nosed pliers. All my other attempts at extraction made a mess and were getting crumbs of crap inside the gearbox...
This sounds like an 'easy' way to deal with it. What could go wrong? :smt073
I'm going to give it a try after work tonight. I'll keep you all posted.
Posted: Tue Jun 09, 2009 8:18 pm
by fishbone79
I forgot to mention, I did pull the pass side up on a ramp so the fluid was all on the D side of the case, and I removed the dipstick so the internals could breath easily.
You don't want to heat it much, just enough so it gets soft and you can squash it with a screwdriver.
Anyway, use at your own risk... ;) I was not pleased with the chunks of plastic falling in the box when I tried removing it the other ways.
Posted: Wed Jun 10, 2009 6:40 am
by rallyguy_777
hate that bugger, a pain in the ass when you need to take the cluster out too:S
Posted: Wed Jun 10, 2009 1:49 pm
by skatedees
So, I had no time to try it yesterday. :smt012
But tonight for sure........
Posted: Wed Jun 10, 2009 2:42 pm
by SiCkSTi04
not related to topic but is there a metal version made for our cars? wat if you have the same problem with the new plastic speedo cable.
Posted: Wed Jun 10, 2009 3:28 pm
by cj91legss
what about a really small pair of channel locks. that's what i did.
Posted: Fri Jun 12, 2009 1:27 pm
by skatedees
So, I busted out my Dremel and went to town on that damn thing. A combination of that, a screwdriver, and a pair of needle nose, did the trick. The speedometer works great.
I'll see if I can take some pics of the aftermath......
Posted: Fri Jun 12, 2009 4:21 pm
by cj91legss
must have been fun... tight space and all.
