Climate control ( a/c ) problem
kd78
Post by kd78 »
Can anyone help with a Climate control ( a/c ) problem?
The dash display is not working... nothing on screen and there is no fan or a/c.
the fuse under steering column is OK, and the fan in engine bay is working.
Do i need to go to my Subaru dealer and have a diagnostic test done :( :( ??
reg year is 93, 2.5 GX
BSOD2600
Post by BSOD2600 »
Some times the circuit board gets cracks in the traces or wire connections, causing it not to work. Take it apart and have a look.
'11 WRX Limited
'94 TW | R.I.P.
Bdub
Post by Bdub »
I had a very similar problem. I found that just taking it apart, cleaning up all the contacts solved the issue. Thankfully, thats all it needed.
Upon searching this problem, cracking of soldered joints is a somewhat common thing.
Through The Generations...
91 SS 4eat
95 LSi 4eat- Sold
07 2.5i 5mt- For Sale
13 STI Sedan
I take it you probably have the automatic climate control correct?
If so, it too also probably suffers from the cracked solder joints. Check out this thread for some more info.
http://bbs.legacycentral.org/viewtopic.php?t=1142
