Factory ignition dwell times & injector injection timing
I know this is probably a long shot, but would anyone happen to know the factory ignition dwell times for the diamond or even hitachi coil pack?
Also, I'm looking for the injector injection timing.
I need a stock car and an oscilliscope...
GodSquadMandrake
Post by GodSquadMandrake »
Oh that's a good question. The dwell time has gotta be somewhere around 2 ms but I don't know exactly.
-Doug Wilson
Got some info from Fineline Imports on settings they use for the Impreza with the same coil setup.
Code: Select all
6v  7v  8v  9v  10v  11v  12v  13v  14v  15v
10  10  8   7    4    3    3    3    3    3 ms
The injector injection timing they use is 400 deg BTDC
Also, I got the injector deadtimes for the STi yellow side feed injectors.
Code: Select all
  6v    9v   12v    14v     16v
7.66  2.69  1.37   1.06    0.75  ms
I need to ask them about my gray Diamond COP's before I get her going.
How far off were the deadtimes?
Not too bad at normal voltages, but off quite a bit at lower voltages.
Code: Select all
Voltage     Deadtimes (ms)
6                3.490
7                2.810
8                2.273
9                1.864
10               1.563
11               1.360
12               1.209
13               1.101
14               1.000
15               0.940
