what next
__TT__
what next
Post by __TT__ »
94 t-leg
stock turbo with manual boost control
wrx TMIC
3" downpipe with exhaust and a forester muffler
Running 11-12 psi
Walbro pump
oh the coffe cup mod is done
What next on the engine? Ive been searching and found
NA fuel rails, bigger injectors and a bigger turbo then manage it all with a standalone management.
Is there something esle i can do before making that step? can I add the fuel rail and injectors and run them with the stock ecu?
hmm maybe the grounding mod tonight for me.
RJ93SS
Post by RJ93SS »
finish the exhuast, injectors, jecs maf, revtronix, bigger turbo
douglas vincent
Post by douglas vincent »
My vote?
Minimum 550 injectors
FMIC
Bigger turbo
Perfectpower6 piggyback.
Kilroy
Post by Kilroy »
douglas vincent wrote:My vote?
FMIC
Bigger turbo
What's one of those piggyback units worth?
__TT__
Post by __TT__ »
FMIC
Bigger turbo
explain why you choose the FMIC please?
RJ93SS
Post by RJ93SS »
FMIC
Bigger turbo
better intake temps over a top mount, a little more work though.
__TT__
Post by __TT__ »
FMIC
Bigger turbo
Doesnt the length of the hose produce more turbo lag, also doesnt the legnth of hose in the hot engine compartment negate any gains you would get from a FIC setup?!
Where you put your filter has a much larger effect on your intake temps than heat transferring through the piping. Its not really a major issue.
The lag thing is a hotly debated topic. The size of your intercooler and turbo play a big part. A small turbo with a large intercooler takes a bit more to pressurize all that volume. A larger turbo will move enough air for a big FMIC to not be a factor. A properly matched front mount for your turbo will not induce much lag, but most of the bolt-in(ish) FMIC kits have miles of piping so that has a lot of volume for a turbo like a VF11.
Also, if you have a wideband (you should have one if you are messing with a turbo car), I'd also consider the Maf Translator Pro for a piggyback, if you don't want to drop the cash on a G4 Storm. Although the Storm would be the better option.
__TT__
Post by __TT__ »
FMIC
Bigger turbo
Good online source for 550 injectors?
macipusy
Post by macipusy »
I've seen the 550s on ebay before, also maybe classifieds on nasioc.com and here
I got mine used form a subaru shop
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
