blue smoke on start up only
just started happening this morning on my dads 92 tw. ecu was reset on friday after the knock sensor was fixed. leak around turbo return line recently developed as well.
turned the car off for 5 minutes and upon start up it happened again. the blue smoke is heavy for 2-3 seconds and then it clears up.
any ideas.
any ideas.
It has nothing to do with warmup. An engine in good shape should never have blue smoke on startup, or anytime.
My guess would be bad valve seals/guides.
http://www.slodriveracing.com
-And more!
-And more!
go start a car move it and turn it off with in 30-45sec than wait 20min. start up and see smoke come out.
1997 Nissan Laurel ClubS25t
1992 Legacy SS(Sold)
SLODRIVE wrote:It has nothing to do with warmup. An engine in good shape should never have blue smoke on startup, or anytime.
that was my dads first thought because it has low k's and it's a 92.
what should he do first, pressure check?
some details on his car:
92 tw
td05
06i/c
k&n
120,000 km
new plugs/ wires
stock tune, waste gate boost 8#
so, he had it into the mechanic today and we had the turbo taken off to fix the leaky hose.
Almost zero shaftplay and no oil in the exhaust side. The mechanic did notice the whole intake was very oily, the i/c was soaked but all the synthetic oil found was very clean.
He repaired some intake leaks and replaced the intake hoses ect.
when we started it back up it smoked again.
Each startup the smoke seems to get worse. It almost starts out as a cloud of thick white smoke but it quickly turns blue as it disperses in air. It lasts 30 seconds to about a minute now.
The old man was planning on heading to Vegas this weekend for two weeks but may not be able to drive his subie because of this.
Were thinking internal engine problems but not exactley sure what?
No overheating issues or oil mixing with coolant or the other way around? Actually maybe at the same time watch your overflow tank for bubbles.
Was there literally a puddle in the intake? I am assuming you cleaned all the intake parts before assembly. Did you also take apart all off the PCV system as well?
all the larger lines on the intake were replaced, bpv, f pipe ect ect.
didnt really clean it up.
zero overheating, no oil, engine seems stronger than mine, though not as powerful
exhaust side was dry, no shaft play, couldnt reach the intake side
when i left the mechanics shop and after the first start the car smoked badly and got less and less until it was gone . now, here is the weird thing, after getting off the phone with him an hour ago, after he left the mechanic he stopped at a dealership to possibly buy a car to go to vegas saturday. didnt find nothing, started the subie, no smoke. drove again for a while, off for a while, restart with no smoke.
so now, there's no smoke.
one day it comes, a few days later it goes. wtf
it seems to be similar to my car. makes a noise, something seems wrong, mysteriously fixes itself later.
i dont know.
wish i had a video.
![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
i dont know.
wish i had a video.
Out of curiosity, does the car use much/any oil? I know mine uses a bit so we're constantly checking it which means occasionally it gets a little overfilled (stupid dipsticks...on the car that is). I notice when this happens it can potentially push more oil vapor out the pcv system into the intake. not sure if this is more likely to be a problem or less on a turbo.
90 Legacy L AWD 5mt
Formerly of the USMB but moved from an RX to a Legacy
