These really must go.
_Aramchek_
Post by _Aramchek_ »
So how does the turn signal situation work out if you put these in your turn signal holes?
You would have to get JDM headlights as well, correct? Otherwise you'd have no turn signals.
On my first legacy I hated having the turn signals down there because they were too hard to see. So I tired up those running lights in the corner lights to the turn signals and after that my turn signals blinked like 3 times faster than normal. It was annoying as hell. So annoying that I eventually rewired them back to stock.
what about your corner lights arent they used for a turn signal ? Hello
No they're not. They're just running lights. I'm not sure about the 92-94 but the 91 the turn signals are in the bumper.
Oh sorry I figured it was like the 92-94. You would need to wire up the turn signals to the corner lights I guess.
Apex3
Post by Apex3 »
I really shouldn't be thinking about this but...Do you need the JDM bumper too? Or will it fit in the stock USDM holes?
Post by SubaruNation »
Should fit stock USdm bumper
drewriviera
Post by drewriviera »
I will take those! Do you take Paypal?
-Andrew
drewriviera
By the way, you can email me at drewriviera@yahoo.com
jefferson
Post by jefferson »
I hate to put water on this fire, but I don't think those will fit the usdm bumper. Our holes are not square where the jdm ones are. Check out a jdm bumper versus ours and you will see the difference.
Jeff
Saskatoon Subaru
Post by Saskatoon Subaru »
yes you need a bumper like mine made for them, which i have and need cause one of mine cracked i need please.
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
you dont necessarily NEED the different bumper.
you can cut and meld the one that you have to fit also
