These really must go.
Posted: Fri Jul 17, 2009 12:09 am
by _Aramchek_
Posted: Fri Jul 17, 2009 12:55 am
by kimokalihi
So how does the turn signal situation work out if you put these in your turn signal holes?
You would have to get JDM headlights as well, correct? Otherwise you'd have no turn signals.
On my first legacy I hated having the turn signals down there because they were too hard to see. So I tired up those running lights in the corner lights to the turn signals and after that my turn signals blinked like 3 times faster than normal. It was annoying as hell. So annoying that I eventually rewired them back to stock.
Posted: Fri Jul 17, 2009 1:25 am
by ericem
what about your corner lights arent they used for a turn signal ? Hello
Posted: Fri Jul 17, 2009 3:02 am
by kimokalihi
No they're not. They're just running lights. I'm not sure about the 92-94 but the 91 the turn signals are in the bumper.
Posted: Fri Jul 17, 2009 4:57 am
by ericem
Oh sorry I figured it was like the 92-94. You would need to wire up the turn signals to the corner lights I guess.
Posted: Fri Jul 17, 2009 7:49 am
by Apex3
I really shouldn't be thinking about this but...Do you need the JDM bumper too? Or will it fit in the stock USDM holes?
Posted: Fri Jul 17, 2009 8:03 pm
by SubaruNation
Should fit stock USdm bumper
Posted: Fri Jul 17, 2009 9:49 pm
by drewriviera
I will take those! Do you take Paypal?
-Andrew
Posted: Fri Jul 17, 2009 10:39 pm
by drewriviera
By the way, you can email me at
drewriviera@yahoo.com
Posted: Sat Jul 18, 2009 3:45 am
by jefferson
I hate to put water on this fire, but I don't think those will fit the usdm bumper. Our holes are not square where the jdm ones are. Check out a jdm bumper versus ours and you will see the difference.
Jeff
Posted: Sat Jul 18, 2009 6:02 am
by Saskatoon Subaru
yes you need a bumper like mine made for them, which i have and need cause one of mine cracked i need please.
Posted: Thu Jul 23, 2009 11:38 pm
by SubaruNation
you dont necessarily NEED the different bumper.
you can cut and meld the one that you have to fit also
