Here's the STi vs. a WRX (very similar to Legacy):
![Image](http://farm3.static.flickr.com/2445/3747108816_0ce89dafb0.jpg)
The pass. side was easy in/out and holes lined up. The driver's side was a PITA as the holes didn't line up. I turned it 180 (around the center/not front to back) and it seemed better, but I still had to use a lever to get it to align....not a lot of pressure but enough to move it about 1/2 of the bolt hole.
EDIT: I had an install issue on another car......just to clarify: the taper / chamfer in the bore of each bushing is visible below - the tapered end goes forward toward front of car.
Now while driving the car pulls to the right.
Did I mess something up or just need an alignment?
P.S. Here are Part numbers as the old ones are obsolete:
1. RIGHT
NEW
PART NO. PART NAME QTY
20201FA050 BUSH AY-T/V LINK 1
20540FA010 BOLT CT/V LINK 2
OLD
20201AA031 OR 20201AA030 BUSH AY-T/V 1
2. LEFT
NEW
20201FA060 BUSH AY-T/V LINK 1
20540FA010 BOLT C-T/V LINK 2
OLD
20201AA041 OR 20201AA040 BUSH AY-T/V 1
STI (cheaper, too!)
Here are the STI transverse link bushings. The part numbers are:
left: B0200FE010
right:B0200FE000
Note the taper between the two.
![Image](https://lh4.googleusercontent.com/-dpnCgrMzTp0/T_HHxI7eWJI/AAAAAAAADyc/Muvfbu74Pn0/s466/STi%2520TL%2520bushing%2520left%2520vs.%2520right3.jpg)
![Image](https://lh3.googleusercontent.com/-ketAQGZzN1E/T--clwMsfcI/AAAAAAAADxI/t3BO3lzMe0c/s256/STIbushings.jpg)
You can see how the taper on the control arm in this pic:
![Image](http://www.autopartsnetwork.com/images/catalog/brand/mevotech/640/MS80102-1.jpg)
