How wide is to wide
Posted: Tue Jul 28, 2009 6:54 pm
by SPUMONI_RT
I'm looking at some wheels and they are 225 R16 they don't have the sidewall on there.
Posted: Tue Jul 28, 2009 7:00 pm
by brand
Um, what? Wheel width is measured in inches.
Posted: Tue Jul 28, 2009 7:46 pm
by RJ93SS
you need offset, rim size tire height ect.
225's are not fitting your stock wheels though, either are 16's.
more details please
Posted: Tue Jul 28, 2009 10:28 pm
by asc_up
The 225's will fit on a 16 inch rim so long as the depth of the rim is at least 7 inches. You MIGHT be able to fit them on a 16x6.5 inch rim, but I'm not positive. Also, the offset will need to be somewhere around +48 to +54 (+/- 1 is fine) and the sidewall will need to be 45 or less.
Posted: Thu Jul 30, 2009 5:42 pm
by SPUMONI_RT
the tires are on the rim the wheels are from a outback. I just needed to know if they would fit but I'm sure I can figure it out thanks.
http://madison.craigslist.org/pts/1280654675.html
Posted: Thu Jul 30, 2009 6:36 pm
by asc_up
I'm sure they'll work just fine if they were on another Subie.
Posted: Fri Jul 31, 2009 1:04 am
by bushlocos
Outback wheels, generally speaking, are too big. They will not clear our struts.
