under steer problem
Posted: Tue Jan 23, 2001 4:39 pm
by Josh Colombo
As far as I know and from personal experience, all of the legacies will under steer, now to what degree depends on things like you said worn shocks or what not.
I had a bad problem with my 90 Legacy, with the suspension geometry screwed up. The best advice I can give to you is, replace you're worn struts. Get a set of KYB GR2's or GSX's if you have the money. Then see how things are. If it's still not to you liking, bump up the thickness of the rear sway bar. I think the stock size is 18mm. that's what I have on my Non-turbo legacy. you may want to bump up to 19mm or 20 or 21mm, but see how replacing the struts go first. The main thing that happens when you upgrade the rear bar is it helps eliminate body roll....mine still has a fair amount of it....well too much for my liking.
hope that helps
Josh Colombo
jcc189@psu.edu < mailto:jcc189@psu.edu>
of beats and rhythm" - ME
-----Original Message-----
From: miller3339@yahoo.com [ mailto:miller3339@yahoo.com]
Sent: Tuesday, January 23, 2001 3:31 PM
To: BC-BFLegacyWorks@egroups.com
Subject: [BC-BFLegacyWorks] understeer problem
Good afternoon all, I have been having a understeer problem under
more
"spirited" driving, mostly on slippery surfaces, I'm wondering if we
all understeer that badly? or if it's my tire pressure? worn shocks??
driving style?? I've heard that a bigger swaybar might help but I
thought that the Legacy Turbo had a big enough one.
you help is appriciated.
Miller.
eGroups Sponsor
<http://rd.yahoo.com/M=174588.1292523.28 ... ealth.html> Click Here!
Click Here!
<http://us.adserver.yahoo.com/l?M=174588 ... =552907679>
