Now that several of us have had Stage 2 in for a while, I'd like to see who is running with a larger turbo, and what peripherals (such as boost control) are being used. Post your experiences.
I just put my VF-8 back on after letting the ECU settle in with the TD-04 and Stage 2 v.2, it is smooth and AFR's are fine.
I'm using the factory BCS.
Revtronix Stage 2 w/bigger turbo poll
1991 SS build thread: http://bbs.legacycentral.org/viewtopic.php?t=40430
TD04 with MBC.I couldnt get the BCS to work so i was running basically wastegate pressure.Now with the MBC i got the boost that i wanted but now have to deal with the really annoying PTFB issue and having to watch my boost guage in higher gears to avoid overbooting.
What is meant by chip controled? I going to but the revtronix chip monday, and i have a MBC. but does the chip control boost w/o a boost controller?
-91ss, 250,000mi rebuilt, tmic, tdo4, agx's w/groundcontrol, f/r strut bars, rust
-83 gl wagon...350,000mi custom dents
-62 honda 55, (moped)
-74 Yamaha rd 350
-74 Yamaha rd 350
Yes, read up on it some so you get the right configurations. The chip is tuned to use the factory boost control system.race_to_live wrote:What is meant by chip controled? I going to but the revtronix chip monday, and i have a MBC. but does the chip control boost w/o a boost controller?
dynoed ??
I havent gotten mine yet,But was curious as to the results ..anyone
jay
jay
