WTB: ej22T complete water pump!!!
jdmleggy97
Post by jdmleggy97 »
Im looking for a complete water pump for ej22t with front not bottom thermostat location. Anyone have one kicking around??? I need on asap!
Aerotech
Post by Aerotech »
How many small hose inlets? Up to '91 has 3 pipes, later has 2.
I have a new one with 2 pipes.
Jerry
jdmleggy97
2 is fine. I have to plug one anyway. How much?
I've got a couple used ones. One is a 92-94 EJ22T pump and the other is like a 95 EJ20H twin turbo pump. Same pump really except the EJ20H one doesn't have the coolant nipple for the oil cooler.
jdmleggy97
I have a turbo pump on my spare ej20r. I just figured it wouldnt work because its dohc. I didn't think they were the same????
Pretty sure it's the same but I could be wrong.
I put the EJ22T pump on my 97 JDM DOHC EJ20G engine which also has an oil cooler like the EJ22T. Looks identical.
jdmleggy97
I just checked part numbers on the gaskets and there the same(using 2.5 non turbo as reference) so they must be. Thanks I guess I dont need it then!
jdmleggy97
but if it dosent work. How much do you want for the pump?
Me or aerotech? I'll send you both pumps for $25 shipped. The one off the twin turbo and the EJ22T. Mileage is unknown on both though.
jdmleggy97
so does the twin turbo pump have the extra nipple for oil cooler ? If so I want it!
Bdub
Post by Bdub »
The 91's had an oil cooler stock, so they have the extra hose nipple.
I have one with only 90k which was operational when I took it off a running 2.2t.
Through The Generations...
91 SS 4eat
95 LSi 4eat- Sold
07 2.5i 5mt- For Sale
13 STI Sedan
abest10
Post by abest10 »
Pm sent. Ive got one from 1 from a 91.
1993 Legacy SS 5 speed sedan
