Transmission Dropping Gears?
hitchhykova
Post by hitchhykova »
If it's not one thing it's another with this damn car.
Today, when I left to head down to Chicago from Wisconsin, when I took off, it shifted hard for no reason, and then had no 4th gear.
Whenever I would step on the gas, the RPMs would jump, then it would grab, staying in 3rd. I've had transmission issues like this before with a totally different brand of car, and the same trick worked with this car...
I turn it off, then start it back up, it works perfectly, all gears, normal shifting.
I've flushed the fluid twice now, the first time I added seafoam, drove for a few days then flushed it again.
What would cause it to do that?
My GL had similar issues when the modulator valve went, but I imagine the computer does that job on the Legacy transmission.
gijonas
Post by gijonas »
x2.Research the valve thing if they have one then that is probably it.
