need help with the power antenna on cd player
yazmo
Post by yazmo »
anyone know how i can fix this issue
i have install aftermarket radio cd player and right now mno matter if i am on he cd player my power antenna rise up
and i dont want this we got big winter here and a lot of bag temper ppl around here.
is ther a way that trhe antenna rise only if the fm tuner is on?
what i am scare of its bcuz the power antenna rise up when i put the key on acc or when i turn the car on and with ice im scare i could brake something
anyone know a fix?
thx in advance
If the aftermarket head unit does not have the option to turn the power antenna "off" when the CD player is on, your other option would be to wire the antenna lead into a switch and manually raise the antenna with a toggle switch.
yazmo
Post by yazmo »
yes josh thx i did it work fine i make a switch
thx u
